P0172 code broken elbow
whites70
Year and Model: C70 99
Post by whites70 »
Ok. So Ive had this code since I purchased the car a few months back and after reading about this one elbow that fails on everyone, I set out looking for it but couldnt find it until I grabed the flash light and looked under the power steering pump....low and behold I found this little booger
Its completely ruined so I need to get another one ASAP. So Im ordering a few but
Now. Where does it go? I cant seem to find where it went.
Current : 2010 Volvo S40 2.4i wifes car
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
whites70
Post by whites70 »
Also is this the elbow I need?
http://www.fcpgroton.com/product-exec/p ... +Connector
or
I would get the kit from IPD but its back ordered and I want this fixed before friday b/c 22mpg on the highway combined w/ $3/gallon premium gas for 600 miles sucks!
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Second one, part #9155862. You don't need to remove the coolant hose if you have the dexterity of an elf. Otherwise, it helps. I used a clamp on both ends because it repeatedly blew off one side or the other. :evil:
Also -> Amazon link
whites70
Post by whites70 »
So for clarification its the nipple circled in this this pix Image
Imasking b/c the elbow in my pix does not look big enough to fit over that nipple. I tried last night to see if that where it went, and it went inside b4 it went over.
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
I discovered that the cap from a Sharpie fits on the hole on the intake perfectly and lodges itself against the power steering bracket. Obviously its not good long term, but It will stop the code and get you your gas mileage back until you have the time\money\parts to fix it proper,
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
matthew1
Site Admin
Post by matthew1 »
whites70, I can't tell if we're talking about the same elbow. You should look at my photos closely and compare them to your car, and let me know.
If it's not the same elbow, forget what I've said in this topic or you'll get the wrong elbow.
Also -> Amazon link
whites70
Post by whites70 »
Fudge. I ordered it today.lol I'll look at it more closely when I get home.
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
whites70
Post by whites70 »
Just took a look, looks like the larger side of the elbow is still attached and the smaller end somehow,dry rotted or w/e, and broke away from the larger side of the elbow. Is there a foam insulation that covers the vacuum running under threre? B/c I can see an insulation of some sort on the line connecting to the broken elbow.
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
matthew1
Site Admin
Post by matthew1 »
We're talking about the same one. The line to the elbow from behind the engine does indeed have a foam insulation sleeve (that makes it even harder to work with, grrr).
And yes, your elbow does look like the fatter end rotted off the rest of it. The part # I gave you is the one you want.
Also -> Amazon link
whites70
Post by whites70 »
Sweet, thanks Matthew, you were right, it came in yesterday and I got it on but not after fighting w/ the foam insert which I got impatient with and pulled the vacuum line to far out and tore the elbow on the other end of the vacuum line at the throttle body.LMAO So I got it on and went up to my local Volvo Specialist and he stocks all the elbows and sold me one for $5. So its all buttoned up now, the light didnt go away on its own after letting the car run for a few minutes. So I pulled off the cable and reset everything, it hasnt come back and Im hitting the road tomorrow so I guess thats the real test.
99 C70 2.4T Sold
98 S70 2.4 N/A Sold
