Car shaking @ 50-60 mph
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
At that speed it usually means your wheels need to be balanced.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
This is my opinion that it is true that an out of balance wheel usually shimmys at 50 to 65mph, however with your model Volvo I would carefully check the drive axels. Also I have seen out of round tires or a shifted belt create problems. When the tires were last changed were the lug nuts torqued to specs? It would also be a good idea to look at the engine mounts
check it out.....Dick K.
MY 960's tires were beginning to cup and scallop. It occurs when the dampener/strut/shock wears out just enough. The wheel makes sub-millimeter skips at speed. It's like when a plane lands. There's that initial acceleration of tires to tarmac.
It caused my car to shake just enough to bug the hell out of me. It's one of those things that you would pick up if you are the owner or a mechanic.
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
- 3763 Views
Last post by jvl
- 5513 Views
Last post by ektrules
- 16 Replies
- 4585 Views
Last post by Jack Rock
- 726 Views
Last post by Ou2mame
- 2927 Views
Last post by hockeyjake1997
