A/C system recirc motor problems
t5rrr
Year and Model: 1994 855
Post by t5rrr »
The recirc motor that operates the outside air damper keeps clicking and resetting itself when I switch it "on" (i.e. closing the damper to recirculate cabin air). See the video:
Looks like the arm gear may have jumped some teeth or motor limit switch is bad??
Anyone had this issue and got it fixed?
Wagon Brigade >> 94 855 NA | 97 Subaru Impreza OBS | 07 Suzuki SX4
Previous Bricks >> 90 240 GLE 2.0 | 98 S70 T5A 2.0 | 03 XC90 T6 2.9
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The teeth on the gear in the motor are broken. You best bet is a local junk yard but if that fails try Erie Vo-Vo. There is a link on the top of the page.
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
Ozark Lee wrote:The teeth on the gear in the motor are broken. You best bet is a local junk yard but if that fails try Erie Vo-Vo. There is a link on the top of the page.
+1
Junk yard shouldn't be to much, Sure you may have to spend 30 minutes getting it out, but hey, 30 minutes and 30$ is better then paying more then you have to.
t5rrr
Post by t5rrr »
Thanks! I'll raid the local yards for one then, looks like a tight fit for the back screw :(
Post by Ozark Lee »
If you are able to find one at a pick-n-pull yard be sure to note the position that the damper is in as you remove it and install the replacement in the same damper position in your car. It is easy to get 90 degrees off which will instantly put you out of range when you hit the switch.
geoduck
Year and Model: 2000 V70GLT
Post by geoduck »
Any tips on replacing this motor? I need to replace mine.
byeboy
Year and Model: 850R, 1997
Post by byeboy »
Where is that located? Where was the picture taken from? Is there a step-by-step to R&R?
Could this be the problematic blend door that causes the double flashing lights?
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
That motor is behind the glovebox and the photo was taken from the passenger's side. I wrote up a DIY on how to disassemble one of the motor actuators...
https://www.matthewsvolvosite.com/forums ... =1&t=51078
