Rebuilt Steering Rack
Some steering racks have a spool valve adjustment if this is not adjusted properly the steering will pull to one side . give it back to the rebuilder you should not have to deal with that. I can tell you how to adjust it, but its complicated
....Dick K.
....Dick K.
- Year and Model: Many Volvos
- Been thanked: 76 times
Before you go through all of the grief of R&R'ing it again did you bleed it? If not throw the front of the car up on jack stands and run it from lock to lock a few times to purge the air out of the system.
If, after you bleed it, the steering is still not right then the rack was bad.
If there was air in the system it would make a loud whining noise and you would notice tiny air bubbles in the P/S supply container. I take the vehicle to a parking lot and circle left and right several times,but I have seen bad racks . The rebuilder that I only use is Mayval.
..........Dick K.
..........Dick K.
- 1229 Views
Last post by dono
- 1244 Views
- 1511 Views
Last post by 800artfreed
- 30 Replies
- 27204 Views
- 1798 Views
Last post by Shift727
