This AM on the way to work I encountered a large puddle. I did not see it in the dark and plowed right through it. The motor immediately began to sputter and loose power. I went approx 1/4 mile and pulled over. The car sputtered and then stalled. it would turn over but not start. of course the battery died and I was towed home. I checked the air filter box and it is bone dry. I hope it is just the wires are wet. The dist.cap and coil do not look as if they got wet. The motor turns over and I do smell gas when I try to start it. I just don't know where to go from here.
Help....
Drove through large puddle now wont start???
Timberwolf530
- Year and Model: 1994 850
It's something electrical. Let it dry out and you'll be fine. If you want to get it going a little quicker and have a salamander (forced air heater) turn that on it.
1994 850 Wagon - My car is on it's 3rd generation in my family. "I don't look at it as doing repairs, I see it as doing a complete restoration one part at at time."
carlr
- Year and Model: 1996 850GLT Wagon
Thanks, I was hoping that was all it may be. Unfortunately I do not have a garage and it is still pouring... Approx how long do you think it will take to dry out in these Massachusetts rains we are having?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Have you still got your belly pan? This thing?
http://www.ipdusa.com/Volvo-850/Exterio ... -246-3106/
- Has thanked: 2861 times
- Been thanked: 1332 times
I'm no waterologist, but I believe rain by definition is 100% humidity, and in 100% humidity conditions things won't dry out. That's what my scientist-wannabe side tells me.
My DIYer side tells me you should put silica bags under the hood -- you know, those packets that are labeled DON'T EAT and come in, uh, food packages.
My realistic side says you'll have to buy a lot of beef jerky to get enough of them to do the job. I'd go under there with a bunch of dry towels you don't use any longer and look around for wet surfaces and dry them. Look in the spark plug holes for water, although I doubt that's the problem because they're at the very top of the engine and well protected from puddles/splashes. My realistic side also says that this idea is probably unworkable, because most likely the areas that are most affected are the hardest-to-reach areas of the engine bay.
My reckless side says to get out a hair dryer, but my survival instinct side says to leave that in the bathroom because it's raining.
carlr
Matthew1,
I pretty much thought the same thing and in that order. I looked at the motor compartment and other than the obvious bottom of the motor the rest is dry. I did unplug each wire from the cap and they were all dry. Maybe if it ever stops raining here in new England I can get it dried out. I may have to have it towed to a garage to get some heat on it.
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
maybe you got some water on the o2 sensors or some water in the exhaust pipes. I don't know if that would cause what you've got going on but maybe.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
- BEJinFbk
I'd go with a warm, dry garage using a forced are heater and maybe a dehumidifer.
But you have an issue that's not gonna just go away. Volvo is pretty good about waterproofing.
I suspect that you've got an electrical connector somewhere that is no longer "mint".
The high voltage ignition parts - Coil, cap, rotor and wires - are the first places I'd look.
When is the last time that stuff was replaced?
If no garage and heater try light bulbs. A 65 watt keeps my car warm when it gets a really cold wind chill in Chicago. Just be careful if its still raining. Electricity and water don't mix well. GL
Jim
Jim
coustyj
2007 V50 Silver Metallic / 73,055 K
Volvo 1 - 1994 850 / Gray / 176,789 rip
Volvo 2 - 2000 V70 SE / Moondust / Manual / 169,892 rip
- 842 Views
Last post by bbach6
- 2521 Views
Last post by chrisb315526
- 4199 Views
Last post by oragex
- 41 Replies
- 5856 Views
Last post by Ou2mame
- 3629 Views
Last post by mrbrian200
