Changing power steering fluid on S80
JDS60R
- Been thanked: 3 times
You can do both. If you vacuum out the fluid before removing the return hose it will make less of a mess.
Place the return hose (safely away from the accesory belt) into a bucket . Then add a section of extra hose to the where the return line went with a plug or lift the line above the resivour so the fluid will stay in the resiviour. Have a friend start the car for a few seconds while you keep the resv full. When you see clean fluid coming out of the return line you are done.
It will be your choice to add an inline filter or magnet to help with wear going forward. Owners manual will specify the proper fluid.
No drain that I am aware of but I wish there was one.
Retired
- 30 Replies
- 27187 Views
- 6109 Views
Last post by EngineeringBloke
- 2456 Views
Last post by Blacklab467
- 1793 Views
Last post by Shift727
- 11 Replies
- 2196 Views
