I have a '96 960 sedan. Just recently the 6 cyl. engine seems to miss or stutter on the highway ONLY when I exceed about 60 mph. If I slow down a bit to 50-55, the miss goes away. Does this sound like a fuel supply problem (pump, injectors, or what??)
Thanks,
Irby
engine miss/stutter at highway speeds
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
How long is it since you replaced the fuel filter and air cleaner. Both of those could cause higher speed misfire if dirty.
Have you checked for fault codes?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
mstebbins815
- Year and Model: 960, 1993
I recently had this same problem with my 1993 960. Replacing the spark plugs did the trick for me.
- billofdurham
mstebbins815, welcome to Matthew's Volvo Site.
Sometimes the easiest solution is overlooked.
Bill.
Bill.
Previously:
Previously:
- billofdurham
Possible but unlikely as it doesn't restrict itself to certain speeds.
Bill.
Bill.
Previously:
Previously:
Update:
While cruising at about 40 mph, the engine(?) seemed to quit and restart rapidly about 5-6 times. I noticed that the gearshift (accidently) was in 3rd range rather than Drive. Could this mean that rpm is suspect? Or, how about the transmission trying to shift? The cutout is really abrupt, NOT like just turning the ignition off and on.
I get the same engine conditions sometimes on the highway above 55-60 mph. I still plan to have the code check done.
Thanks again,
Irby
Thanks again,
Irby
- 3547 Views
Last post by johnmatthew
- 18335 Views
- 2493 Views
- 1029 Views
Last post by E Showell
- 12 Replies
- 3256 Views
Last post by willysmd
