DIY: Car Alignment Tricks Using Common Tools
This topic is in the MVS Volvo Repair Database » DIY Alignment Using Common Tools
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I just did the Alignment Tricks Using Common Tools.
I tried it on my 1998 Volvo V70 and it works perfect!!! So here is the DIY.
The key thing is to define the axis of the car by making parallel lines along the forward axis of the car.
1998 Volvo V70 Alignment Tricks Using Common Tools.
Toe-in measured at tires 2.9 mm +/- 0.9 mm.
Tools required:
* Carpenter Level at least 24" long
* Carpenter Square
* Plumb Bob
* Masking Tape and Pencil
* Basic Skills involved in Tierod adjustment
The following procedure shows you how to adjust toe-in (adjusting camber and castor requires special tools, and but these rarely need to be adjusted unless you just did spring/struts). So this toe-in procedure is usually good enough for annual maintenance.
Although this is from a 1998 Volvo V70, you can practically use this procedure on any car.
NOTE:
- Most cars have negative Toe-in because when the car runs at 50-60 mph, the wheels "flare out" (or toe-out) a bit from the forward force and crown on the road, now the tires are parallel when driving.
- Any worn Suspension components need to be fixed before doing this. At 80-100K miles, common items are: Outer Tie rods, End Link Swaybar, Control Arms.
- Garage Floor needs to be level between R and L sides. The normal slope seen in typical garage floor slopes outward and this small slope does not affect this procedure.
- Do this inside garage to avoid wind blowing the Plumb Bob.
- Tires should be the same make and wear. Inflate all 4 tires to approx. 35 psi or so. Unload any heavy cargo in the car.
1. Start by attaching Carpenter Square to Carpenter Level using Zip Ties.
2. Using a brick approx. 24 cm tall for support, measurements are made at "equator" of tires. Use a chalk to mark the tires where measurements are made.
3. Set Steering Wheel Straight.
4. Track widths for FRONT and REAR tracks are rarely the same in any car, so one needs to record this to establish parallelism:
5. Start by holding the Carpenter Level/Square Combination so the Carpenter Square is now at the Hub (Axis of rotation of Hub), drop the Plumb Bob within 2 mm of floor, mark an "x" on the floor with pencil.
6. Do this for all 4 wheels. Back car out of garage to measure track widths (including the Carpenter Level/Square Combination). In my case Front = 212 mm, REAR = 206 mm.
7. Drive car back inside garage at similar location. Apply Masking Tape on floor, long enough for the entire tires (see pic).
8. Repeat Step #5, but add 3 mm for the REAR "x" mark. Now you have 4 points that define the perfect rectangle, which defines the forward axis of the car straight movement.
Using a brick to hold the string down and pull it slightly tight enough to draw a straight line (using the Level to draw straight line) between FRONT and REAR points. Now you have a straight line parallel with the car.
9. After this stage do NOT move the car. If you do, then you must repeat Steps 1-8!
10. Now start alignment job: for EACH tire, do NOT measure at Hub but instead measure at tire side walls at "equator".
11. In this example, RIGHT FRONT Tire Toe-in is 5 mm and needs to be about 2.9 mm according the Volvo spec's.
12. Adjust by: Loosening the Locknut, turning the INNER Tierod using 13-mm wrench. Re-measure. The steering wheel may be pulled out of straight, do NOT worry about this yet.
13. Now adjust LEFT FRONT Tire Toe-in.
14. Tighten the Locknuts.
15. Check the Steering Wheel, it should be close to midline (should not be too crooked).
16. Note that the wheels now are according to alignment specifications, but the Steering Wheel may not be straight. Do NOT worry about it for now.
17. You will need to do another adjustment soon.
18. Go for a test drive on highway, if Steering Wheel is straight, then you are done. If not, you can either: ignore it or fix it.
19. I am a perfectionist, so I fix it. On highway drive, I noted that the Steering Wheel points at 1 o'clock position (car drives straight though). Write down your observation. If you screw this up and adjust it wrong in Step 20, you will have to repeat the whole thing!
20. Basically in my case, when the Steering Wheel is returned to 12 o'clock (or neutral position), Both Front Wheels are now slightly pointing LEFT, but they are still within spec's.
21. Do equal adjustment on both sides: if you turn the LEFT FRONT tire Inward by 2 mm, you turn the RIGHT FRONT Tire Outward by 2 mm.
22. Test drive again. Whatever you do, once the tires are aligned, you always do EQUAL adjustment on both sides to avoid repeating all these steps mentioned above!
Car now drives beautifully in a straight line! Do NOT forget to Tighten the Lock Nuts.
23. Enjoy the drive and you just saved $70 alignment cost for beers/wine!
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
This is my method of choice. Its very quick and easy with basic tools.
http://www.pelicanparts.com/bmw/techart ... toe_in.htm
Ambitious but rubbish
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
While I'm sure these methods work well they seem a bit over thought and over-engineered. Toe in/out can be measured using tire tread groove measurements on front and rear of tires. If you have two people you can use a tape measure. If you are solo you can use a long stick with a nail in it to grab a specific tread on the front of the tires on the far side of the car from you. Mark a specific point on your side of the car on the same tread edge. Next, reverse to the rear of the front tires and take the same measurement on the same treads. Compare measurements. Obviously a larger measurement on the rear indicates toe-in and vice versa.
Adjustment can be accomplished by cracking the hold nut on the tie rod where the inner goes into the outer. Spin it out a bit. Using two crescent wrenches hold the flat contour of the outer tie rod while grabbing the inner tie rod at the spot where it is hex shaped and turning the inner tie rod the appropriate direction to create the desired effect. You can get the direction right by having the lock nut very close to the tie rod end and observing direction of movement. Remember, if you started with the steering wheel true you will need to adjust each side equally. Your movements will be amplified as the other side of the tire comes in/out as much as the side you are adjusting so turns on the inner tie rod of a half a turn are a good place to start. If you are looking to change by a 1/4 " I would be at a quarter turn or less as an example.
After an adjustment you will need to drive the car a short distance and re-measure.
1998 V70 GLT, 15G swap
Fairfield, CT
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
