2003 v 70 front brake pad replacement
After a $495 quote for front brake pad replacement (no doubt they will recommend a roter replacement aswell), I was hoping someone might have a step by step instruction manual or just a good memory of past experience. I understand that after I jack up the front end, remove the wheel I should use a 7mm hex to remove the pins (?) Is this correct ? There are no bolts to remove? And what is the best way to push the piston back? I know its just $495, but come on; were living in a depression! The rotor appears to be a little worn, but I;ve replace pads on alot worse. Thanks for any help.
JDS60R
- Been thanked: 3 times
He he - $495. I
I cahrge $350 for that set including and incredible set of very high quality pads. I couldn't say $495 with a straight face.
Do your self a favor and buy good pads. These cars are pretty picky about squealing if bad pads are used.
My customers prefer www.centricparts.com components. I have to drive downtown to get them but they are worth it.
Instructions attached. Do this without a beer and you can have both sides done in a hour. 1.5 if its your first time.
$495 - That's funny
$495 - That's funny
2003 V70 Front Brakes.pdf- (304.4 KiB) Downloaded 551 times
Retired
I'd actually recommend going back with Volvo pads. Have you seen this?
http://volvospeed.com/850fbreak2.php
JDS60R
Volvo pads are Fine.
I do not use them unless requested as braking performance is lower than others available and dust is higher than aftermarket. Stock is a quiet ,dusty pad that could have better performance.
Nothing wrong with it but you can do better with the right pad.
Retired
I replaced my rotors and pads 04/2008 @ 80K w/EBC green pads. I am happy with these, easy to clean with brushing off as needed. I have never had "new" Volvo rotors and pads. I will say,,, the disc metal is made thin, or thinner ...My rotors had a wear pattern at .065" deep..
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
- 3176 Views
Last post by styoung94
- 1012 Views
Last post by scdk
- 1526 Views
Last post by Dunks
- 1837 Views
Last post by SonicAdventure
- 866 Views
Last post by 98v70dad
