Does an S70 OEM radio amplifier exist?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Sure.
Depends on which system. Behind the radio or under the passenger seat.
But more to the point, is there anything plugged into the AMP connector
on your HU? If there is, you have an amp.
figmentj13
- Year and Model: 2002 XC70
Is there anyway to bypass the amp?
RIP: 2000 V70 SE <- Rear end while parked.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
If it's anything like the SC-xxx radios in the '97 850, you can run the speakers off of the HU without the amp. Pull the amp connector off the back of the HU and wire the speakers directly to the HU. Do a search for a pinout chart of where the wire connect properly. I haven't seen a Volvo amp, but my guess is that the wires aren't long enough to reach the HU so you'll have to splice in extensions - not too bad if it's mounted in front of the heater core, but it'll be a pain if it's mounted under the seat.
If you're having a problem with the amp, it might be easier to replace it, either with a unit from a junkyard or an aftermarket amp.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
for s/v70 the amp, when fitted, is just behind the heater core housing. That empty area that makes a heater core so easy becomes a tad less easy as you have to remove the amp. I can't remember if that is only on Dynaudio outfitted cars or if it is an amp that was factory fitted as some other audio upgrade. I have one and the wiring is very easy. Amp has leads that run up to the area behind radio and the other leads for power an ground wire in up there too.
JRL
- Year and Model: Several
- Been thanked: 16 times
SC 900s and 901s have the 4x50w amp UNDER THE PASSENGER'S SEAT
AN 815 or 816 does NOT have an amp. It's a small self contained amp in the radio.
Can you add one, yes, does it sound better, YES
figmentj13
Thanks JRL... After looking I have an 815 so that's good.
JRL
Double checkfigmentj13 wrote:Thanks JRL... After looking I have an 815 so that's good.
iIt may have a small amp behind the 816
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Some 816's have an amp mounted in the center console down where the heater core is.
'98 S70 T5
2016 Chevy Cruze Premier
- 1154 Views
Last post by BEJinFbk
- 1797 Views
Last post by RickHaleParker
- 1548 Views
Last post by TWC
- 2233 Views
Last post by theWIFES_S70
- 1252 Views
Last post by Rattnalle
