2000 S80 fusebox
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
speedman
Year and Model: S80 2.9 2000
2000 S80 fusebox
Post by speedman »
Hi there, this is a newcomer, I just want to check all the fuse in my 2000S80 but I have no idea where the fusebox and how its layout, does some one have some layput picture of it please? Appreciate it a lot.
xtrattitude4u
Year and Model: 1998 S70 2.4l N/A
Post by xtrattitude4u »
It is located under the hood on the driver side next to the fender. There should be a black plastic cover that says "fuses" or "relays"
JDS60R
Been thanked: 3 times
Post by JDS60R »
Here is your owners manual. it will tell you where all of the fuse boxes are
s80_2000.pdf
(2.85 MiB) Downloaded 866 times
Retired
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
xtrattitude4u wrote:It is located under the hood on the driver side next to the fender. There should be a black plastic cover that says "fuses" or "relays"
There's another one in the "end" of the driver's side dash. You have to open the door and remove a plastic panel to see it. There's a third one in the trunk on the driver's side.
speedman
Post by speedman »
Thank you very much guys.
