1800 E- Electrical problem
Re: 1800 E- Electrical problem
No master fuse unless it's been added. Check battery ground, fusebox, fuses, junctions, connections. You'll be facing mysteries like this until you deal; with every connection you can reach in the wiring. Start with a modern fusebox & fuses. Tin every joint and connection. Get it over with Now.
self-tinning solder is the right stuff.
Also learned something from the Maytag man.. douse with electrical cleaner, and while wet, re-crimp old crimped connectors. Works on washing machine rotary switches so it ought to work on a 122s
