All of a sudden my T-5s turbocharger is either over boosting, no where near as badly as the first drive home, or the wastegate has stuck.
Boost needle is now sitting at 3/4 @ 50-80mph before that moves with the gearchange
Car slightly hessitates at 60-80mph slightly but definatly there
Will check the system once the engine cools down
Turbo over boosting/wastegate not opening
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
VACUUM LINES!!!
'98 S70 T5
2016 Chevy Cruze Premier
That's what I'm thinking........or hoping..... I did notice was the chaps assistant said my BCS lines were on the wrong way and swapped them over not sure why it didnt show up on the dyno run after remapping maybe it did but wasn't picked up, I've called the company who have said if it continues get the car back to them and they will recheck the map
Forgot to add it's just had a remap on the ECU now runs 285bhp and 375NmTorque.
jblackburn
Here's the 3 lines from the TCV to the turbo:
What remap did you use?
'98 S70 T5
the remap is a RICA 304. Once the engine has cooled I'll have a look
Update on the problem checked all vacuum hoses none split/moved all correctly fitted so I moved onto the wastegate to see if it was stuck it wasnt but took 6 turns at a pressure of 4psi to get the pin to drop on the rod cap once that was adjusted took the car for a test run completely different boost ok now
The problem is still there at the top of the boost. How do I test the BCS? and or is there another test I can peform before ordering a new BCS
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Not 100% sure what you mean by BCS. If you are referring to the TCV (Turbo Control Valve, n volvo terms if you will) then this will help:
http://minimopar.knizefamily.net/solenoids.html
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
The electronic unit on the airbox with three hoses Yellow/Red/Blue is what I'm calling the Boost control solenoid you might call it a TCV then there is the other electronic unit on the fresh air hose I call a PTC no idea what you call it.
jblackburn
Any luck tracing the vacuum hoses to see what goes where? I suspect that they're just hooked up incorrectly at the ports on the valve itself, usually that's the reason for overboosting and fuel cut.
Usually as the TCV starts to fail, you just loose boost pressure as the valve doesn't like to open up anymore.
'98 S70 T5
- 1160 Views
Last post by nthnnxn
- 5505 Views
Last post by ektrules
- 11 Replies
- 2935 Views
- 17 Replies
- 981 Views
- 2010 Views
Last post by EngineeringBloke
