Oil like substance in coolant reservior
I recently replaced the retaining clips for the trans. mission lines, the bottom line had a small leak. In order to do this I disconnected the coolant hose below the trans. cooling line, the coolant was a milky green. I was told that transmission fluid might be mixing with the coolant. Upon futher inspection I found that there is a dark oily substance in the coolant reservior, not red like trans. fluid, almost like engine/motor oil. After replacing the clips, I flushed the radiator of all remaining fluid and put in fresh coolant. After a day the oily substance returned in the reservior but the coolant is still a clear green. Any ideas as to what this may be.
cmblackburn
If it looks like oil it might be oil...Do s80's have oil coolers built into the radiator? I know s70's do...
JDS60R
- Been thanked: 3 times
Most likely oil.
You should have a square oil cooler on the back of your engine. It needs to be tested and eplaced if it cant hold pressure.
If not then you have to suspect a head gasket etc.
Take a look at the oil and transmission fluid to see which one is getting cloudy or if you see steam coming off of it once it heats up.
Retired
- 1706 Views
Last post by shani10k
- 12 Replies
- 3430 Views
Last post by CNGBifuel
- 795 Views
Last post by UgDriveCar
- 4506 Views
Last post by rspi
- 1295 Views
Last post by bmdubya1198
