My 01 S40 has a consistent idle stumble and hard acceleration problem. I get misfire #2 and #3 codes (302 and 303). It is worse is cold/wet weather at start up (especially when in drive) and also consistently stumbles on hard turbo acceleration. Otherwise around town and on the highway it performs fine. I've replaced the plugs, swapped the coil without moving the misfire code location, unplugged, cleaned and swapped the injectors and tested the spark on #2 and 3 with an inline spark tester light and that shows good consistent firing.
I am thinking maybe MAF but why only #2 and 3 cylinder misfires? Is it worth trying to clean it or just replace. i hate to spend $200 without a firm indication or code.
Thanks
2001 S40 Misfire problem
- 19 Replies
- 10234 Views
Last post by Barledge
- 2169 Views
Last post by S40Colorado
- 3933 Views
Last post by mcnabbr1
- 2857 Views
Last post by Bodhi5
- 18 Replies
- 3644 Views
