Replacing TCV hoses
The vacuum hoses on my TCV (Turbo Control Valve) are pretty tore up. My silicone replacements are here. How do I reach the other end of the red labeled hose at the compressor? Is it easier from underneath the car, or do you have to reach down in there from above? I know this is a lazy question, but I'm asking it anyway.
I had much better luck throwing a thick blanket over the top of the block, about center, and laying on it from the front of the car. Reached in from drivers side too. From underneath I could access coolant and oil lines. Its like playing twister, watch for cramps.
Removing the top of the airbox then raising the bottom part makes it far easier to replace your hoses on the TCV, if they're genuine Volvo ones with the spring clips a pair of long nose pliers or Clip R removers work well you wont need new clips with silicone pipe if its not like mine and old
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Yeah you definitely have to take the airbox off. I replaced the air intake hose and the one that goes to the wastegate, but so far I can't reach the bottom of the one that goes to the compressor. When I follow it down there is grease or oil residue all over it. One of my mechanic neighbors had a look and said it's a real pain to get that one unless you take apart the exhaust system. I'm impressed with anyone who can replace that hose without doing so. I'll keep trying.
The part of the hose that I'm most worried about is at the top where it goes into the TCV. It's kinda stretched and collapsed. I may put a short piece of silicone hose into the TCV and join it to the other one with a connector. I thought this might be recommended against because it could change the pressure, but if the connector is wide enough I don't see why it would be a problem. And this is a GLT "light turbo", so as long as I don't gun it off the line I don't think it'll blow. I'll use clamps on the connector.
Utter utter utter rubbish you do not have to undo the exhaust !!!!!!
Remove the fresh air hose from the airbox to turbo charger then remove the airbox both top and bottom halves you then have access to fit the compressor pipe, sheesh I use a wheelchair and I managed it, ok you will get covered in oil but hey a little bit of dirt never hurt anyone
Silicone is easier as once you start it sliding it will slide over the pipe
volvo seemed to delight in the 1990's of fitting the largest engines into the smallest spaces possible it seems, you just have to look at a 760 GLT with A/C, the 740 Turbo or even the 960 engine tiny engine bays massive engines
That's true, Volvo must've had little elves working for them in the 90's.
I'm sorry, but I just don't see where I can fit my arm in to reach down to the other end of that hose. Perhaps if some other things were removed. I started to take off one hose that's in the way, but it turned out to be a water hose. I quickly re-tightened the clamp before water started shooting out.
I'll have to post a picture. Until then, I already cut the end off the old hose and used a vacuum connector to attach it to a new silicone hose that's going into the TCV. Now at least it's not collapsed. Works just fine.
Maybe next time I replace the distributor cap and rotor I'll have more room to work with.
- 1563 Views
Last post by CleanGreen98
- 1092 Views
Last post by wizechatmgr
- 961 Views
Last post by songzunhuang
- 92 Replies
- 36054 Views
Last post by Sommerfeldt
- 797 Views
Last post by JRev
