20g on the cheap
raint5
Year and Model: 1996 850 t5
Post by raint5 »
i mentioned this on volvospeed and got chastized before i could even explain myself, but i have done more research and thinking, i know that a dsm turbo will not bolt directly up to volvo, however i was thinking that if you fully disassemble the turbo, removing the intake and hotside of a dsm 20g, and put the volvo housings on the core, i dont see why it wouldnt work and still look stock even.
soon to come, mbc; boost, afr and oil press. gauges
raint5
Post by raint5 »
the turbo cartridge should be the same, correct me if im wrong
td05 cartridge.jpg (12.73 KiB) Viewed 838 times
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
If you can fit it into the 18-19 housing there won't be a problem ok you might need to adjust the manifold for the offset on the turbocharger housing.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
