Instrument panel lights MIA
AnnaCB
Year and Model: 1994 850 Turbo
Post by AnnaCB »
Hi folks!
Yesterday, my dashboard went completely dark. Warning lamps still show for a moment when I start the car, so they aren't affected. My little digital readout (mileage, etc.) still works, I just can't see it at night anymore!
ALL of my other front panel lights are completely gone- the lights on my stereo, the AC lights, everything.
I checked the fuse for slot 35 (Instrument panel lights, power sun roof) and it was fine. In fact, I replaced it anyway, just to be sure.
The thing is, the fuse is fine. Not only that, but my sunroof still works with no problems.
What the heck? Am I looking at the wrong fuse?
Would this be a short somewhere else, and if so, where in the world do I start? It's extremely inconvenient to not be able to see anything, not to mention potentially dangerous.
AnnaCB
Post by AnnaCB »
Whoops, I jumped the gun on some of this.
Apparently the AC switch lights and the stereo light are fine.
What aren't fine are the speedometer/other meter lights and the light behind my digital readout and things like that.
When I turn the switch on for those lights, they don't work, but it STILL turns on the running lights (or whatever those lights are called); i.e. the tail lights and such. So the switch itself still works, as well as the sunroof motor which is supposedly on the same fuse as those lights. Is this just a multiple bulb failure or is there still a wire or fuse somewhere that can be messed with? This was an extremely sudden failure of all of them.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Did you just clean the inside of the car and accidentally hit the "Dimmer" switch wheel?
AnnaCB
Post by AnnaCB »
Absolutely not. I've been fiddling with the dimmer switch along with everything else, trying to get this fixed. That question seems like the equivalent of an IT professional's first question being "did you try turning your computer off and then back on again?" I'd love it if it were that easy.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I agree - Check the dimmer.
They also go bad, so you may just need a new one,
but they're pretty easy to change out, so no biggie!
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
That's a lot of bulbs to go out at once. Dimmer good possibility (failed unit, or coonector to it).
Does the sunroof work?
1996 850 Turbo Wagon
AnnaCB
Post by AnnaCB »
Yes, the sunroof works fine, I replaced that fuse anyway, just to be sure.
AnnaCB
Post by AnnaCB »
Any suggestions on how to check the dimmer or connector, or perhaps a link to someplace that could tell me?
Post by cn90 »
Gently pry out the dimmer switch.
Disconnect the switch.
Now short both ends of the connector, if all lights are ON, the dimmer is bad.
AnnaCB
Post by AnnaCB »
Thanks a lot! I'll let you know how it goes.
