It's a 1998 V70 wagon. On the back, it says
V70
AWD
It has the small hose coming out of the front of the airbox. It also has a throttle disc with NO lip on it, that's right, a perfectly flat throttle disc, I saw it myself while I was in the process of doing the ol' throttle plate/disc swap from a 960.
So am I crazy or what?
I can't figure out if my V70 is a turbo or not!
Just because it says AWD doesn't mean it has to be a Turbo, I did think most were LPT 2.5, the fool proof way of checking is look at the exhaust manifold if you can see a turbocharger or anything large and round on it then it's a turbo model, the instrument panel should have a Turbo gauge too. If it is a turbocharged engine and you've swapped the throttle plate from a 960 then you will have to port the inlet manifold or you supposedly stand a chance of the throttle locking on boost.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
JRL
- Year and Model: Several
- Been thanked: 16 times
If your engine has this BIG BLACK PIPE over the engine it has a turbo.
No pipe, no turbo
No pipe, no turbo
JRL
Actually it does. No turbo, no AWD. There are no non turbo AWD'scharlyW wrote:Just because it says AWD doesn't mean it has to be a Turbo
As the previous poster says the black pipe part of the intercooler says it has a turbo. Maybe in the USA AWDs are all turbo seen a few in Europe that haven't been but what is in a badge?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's a low-pressure turbo, 2.4L 190 hp engine.
'98 S70 T5
2016 Chevy Cruze Premier
- 1402 Views
Last post by jking4020
- 11 Replies
- 3717 Views
Last post by wizechatmgr
- 30 Replies
- 10838 Views
Last post by RickHaleParker
- 921 Views
Last post by manovlov
- 817 Views
Last post by - Pete -
