Fixing the Air Conditon
I believe that all it needs is freon, when I tried the AC something under the hood kept making a ticking noise that would come and go while the ac was running.SilverS70 wrote:Well, whats wrong with it? You can add a can of freon but if thats not your problem, that won't work.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
That's the compressor cycling on and off. You are indeed low on R134A but you can refill it yourself for cheap. However if it leaks out fast, less than a month, your EVAP is probably gone.
- 12 Replies
- 887 Views
Last post by pilsbury88
- 2744 Views
Last post by victoriaemmy
- 4020 Views
Last post by Homebrand
- 15 Replies
- 4131 Views
Last post by Rsokk
- 608 Views
Last post by Rsokk
