It getting hot and my wife and kids say Fix the AC. I know there is a leak in my system. And it seems more than likly its the evaporator from what I read. I would like to try and do a leak test before I take 10+ hours pulling the dash out. However, at this point the clutch will not cycle on, to pull Freon into the system. Is there a way to bypass the clutch, so that I can at least get the freon in so I can find where its leaking out.
Thanks,
Eric
140,000 mi
A/C compressor not engaging
jonesboy1983
- Year and Model: V70 2007
One of the experts will respond I'm sure but I will give this a shot. I think the compressor stops coming on if the freon gets too low. If you add a can via the low port I think it should come on if it is working properly. So you can add a can with the uv dye in it and then look for the leak.
- phils94850
- Year and Model: 2009 s60 turbo
yep... thats right, if the press. is to low or to high the compressor wont kick on. try adding freon til it kicks on..
1996 Platinum Edition
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
There is a switch on the firewall near the compressor. If you can short this with a paperclip, the compressor will engage and allow you to add freon into it.
'98 S70 T5
2016 Chevy Cruze Premier
- 1356 Views
Last post by MadeInJapan
- 22 Replies
- 9322 Views
Last post by 5ft24
- 917 Views
Last post by Jat007
- 18 Replies
- 2692 Views
Last post by ducksaysquack
- 774 Views
Last post by beigg
