Cyl head bolt/tap specs, 2001 s80,6cyl, 2.9L
Yes, I broke two of the cyl hd bolts. Getting ready to drill them out and want to be prepared with the tap. Specs pls ! Also, looked at the posted description of the timimg tool for holding the cams (mainly dimensions). Any dwgs available ?
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
See two attached files re: torque.
Unfortunately I don't see any place where it gives the specs of the bolts.
Just measure one of the ones which didn't break with a thread gauge and/or micrometer or take to a machine shop and get them to measure for you or call an engine rebuilder or call a dealer and ask the service department manager....
tightening torque 2001 S80 T6.pdf- This is for T6. Not sure if yours is a turbo or naturally aspirated?
- (51.94 KiB) Downloaded 587 times
Installing cylinder head 2001 S80.pdf- This is for T6. Not sure if yours is a turbo or naturally aspirated?
- (446.69 KiB) Downloaded 1208 times
- 1738 Views
Last post by petermetzger
- 1787 Views
Last post by Livens
- 17904 Views
Last post by beoutside
- 6601 Views
Last post by aksger
- 13 Replies
- 8532 Views
Last post by lifeofgold
