Hey guys! It's been a while... my 850 has two codes coming up P131 and P137. Any help, advice or antidotes would be appreciated.
Thanks!
850 Turbo throwing two codes P131 and P137
claymore850
- Year and Model: 850 T5, 244, V70 2.4
The code p0131 is coming due a failure in the signal of the Engine speed sensor, this condition are set if the ECU does not receive signal from the RPM sensor for 20 revs of the engine, the possible source is a break on the signal cable of ground lead. signal lead short to ground or voltaje, contact resistance in connector, defective RPM sensor. Start cleaning the connector.
The P0137 is throw by the failure of the Bank 2 O2 sensor, check also the connection for rust. or change it..
- 15 Replies
- 2465 Views
Last post by obayha
- 3140 Views
Last post by 2001downunderxc70
- 13 Replies
- 2964 Views
Last post by mrbrian200
- 21 Replies
- 2606 Views
Last post by MagnificentSin
- 4792 Views
Last post by warcraftjunkie
