Hello all,
I am in the process of replacing my brake pads ('01 V70). Rotors are in great shape according to the local dealership. Anyway, doing a little searching around I am stuck on which pad to get: ceramic or semi-metallic.
What are the best pads out there? I am leaning towards the ceramic pads, who is the best manufacturer?
Thanks for your time.
Best Brake pads
hornetdriver
- Year and Model: 2001
Thanks for the reply.
Do you find an increase in rotor wear with the ceramics?
Anyone see a problem mixing ceramics up front with semi-metallic in the rear (as my rear brake pads are still good to go)?
buck
- Year and Model: 03 xc70, 03 s60 awd
Theres no problem with using ceramic in the front and semi-metallics in the back.
For inexpensive ceramics I've had great luck with the Wearever ceramics from Advance Auto, virtually dust free, quiet and stop well for about $45. Napa sells a good ceramic pad but they're about $75 if i recall correctly.
Akebono Euro series Ceramics are great and go for about $65 i think, depending where you get them from, they stop great and are long lasting also.
I've never used them but I hear the Hawk pads are about the best out there.
re: rotor wear, the metals are softer,, in my Opinion, and published as such. BRAKE PADS,, I have been using EBC green stuff, Ceramic and Kevlar,,so far and 24 months later I like them, ..easy to clean dust..I brush the wheels off. I removed the Rear pads 1 month ago and ,,so much metal in the OEM.. Remember Brakes are measured by how well they work under extreme heat.
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
hornetdriver
thanks fellas.
Garage door spring just broke, so the brake job just moved down a notch.
hornetdriver
Alright, garage door is fixed.
Piece of cake really.
Ordering the brake pads tonight. On the fence regarding EBC or Hawk. Really, probably does not matter, it's not like I race the XC70!
I'll get back to the lurkers later, hopefully with pics for the inspiring DIY.
HD
HD
- 2423 Views
Last post by SonicAdventure
- 14 Replies
- 3878 Views
Last post by instarx
- 2358 Views
Last post by cork5695
- 786 Views
- 4148 Views
Last post by Walru5
