Where is Fuel Pressure Regulator on 1998 V70 XC AWD
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Does this help?
https://www.matthewsvolvosite.com/forums ... 4&p=135182
jablackburn wrote:
That almost sounds exactly like the fuel pressure regulator. Which, on an AWD, is a COMPLETE PITA to get at, because it's on top of the fuel tank. Get a fuel pressure gauge and see if you can figure out anything else.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
Well i am on that thread as well but i guess im hoping that somone has does this swap out before and may have pics or some sort of guidance. Do i need to drop tank? can you access this through access panel ... etc
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
You have to drop the tank... OR if you are careful, you can cut a hole in the metal above it (in the trunk area) and make your own access port. There have been a few discussions about that on here, and so far it seems like a pretty good route to go.
When it comes to replacing my fuel pump hopefully in the far out future (knock on Swedish steel), I'll probably opt for the cutting method as it doesn't seem too difficult.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That's the fuel pressure damper. An XC/AWD model has a different fuel system than the rest of 'em, but the regulator is at the back of the car.
https://www.matthewsvolvosite.com/forums ... 6&p=121589
^Take a look at the PDF there.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
This is from a Porsche forum, but explains the differences between the two components:
On a 928, you'll notice that the "damper" or "dampener" is located at the "IN" end of the fuel rail. This seems odd at first, because the damper is there to absorb pressure waves in the fuel rail from the injectors, therefore it should be at the end of the rail, no? No. Since the 928 does batch fire, the injectors all fire at once , ergo no big waves.
However, the Bosch roller cell style fuel pump does generate some pressure waves - so the damper is really there to absorb those waves, and to act (sort of) like an accumulator. It builds up a "pressure reserve" before all them durn injectors fire again.
The regulator does just what you think it does - it regulates the pressure the injectors 'see' by allowing a certain amount of fuel to be returned to the tank. The vacuum reference allows more fuel to return to the tank during periods of high vacuum (like ~25 kPa absolute) like you see at idle, or during over-run.
How? The damper is just a spring loaded diaphragm and so is the regulator. Though the 928's damper is vac referenced, most aren't. Think of it as a trampoline in a tube. Or (almost exactly) like one of those anti-hammer jugs you put on your hot water lines. Tube contains a flexible membrane on one side, and a spring on the other. Fuel flows under the membrane, membrane flexes at some predetermined rate to absorb the 'jumping' fuel pressure.
'98 S70 T5
vjaneczko
I guess you're getting all these answers to help figure out what shops to avoid!denvaa wrote:I was just told by three places it on the fuel rail for my model 1998 V70 XC Turbo AWD .... why am i getting so many answers ... ugggg
2006 S60R - For ME!
2006 S60R - For ME!
That is for a 2000 its the same for 1998? I was told the damper was not used untill 99jablackburn wrote:That's the fuel pressure damper. An XC/AWD model has a different fuel system than the rest of 'em, but the regulator is at the back of the car.
jblackburn
Yes.
Here are the instructions for a 98 XC (I think they're identical).
My 98 T5 has a dampener, but like I said, they're different in the AWD models.
98xcfuelpressurereg.pdf- (58.1 KiB) Downloaded 855 times
'98 S70 T5
- 318 Views
- 16260 Views
Last post by Richard99
- 12 Replies
- 9561 Views
Last post by michael8888
- 4946 Views
Last post by JeffHicks
- 1550 Views
Last post by misha
