Oops I did it again - and I need ideas.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I picked a '98 S70 T5 this evening for my daughter to replace her Porsche 944. It was well bought but it has issues.
The A/C had a minor low charge and a can of R-134a fixed that right up - it was still holding 70 PSI static so.....the Evap may wait for a while.
The big issue of the day is the passenger's side rear window - it won't close. I tried contact cleaner on the switches which usually works in the 850s but no go. I got to the point where I hooked a battery charger up to the Red/White and Green wires off of the rear window switch and still nothing in either polarity. Schematically those wires go directly to the motor - does anyone have any other tricks?
Brazuca_ny
Year and Model: 2005 v50
Post by Brazuca_ny »
meter it out it might be shorted, is the fuze intact, check for continuity on the wires they might be open, just some ideas.
97 850R, 128000 RIP
96 850 R, 150000,flame red SOLD
2012 S60 t5 amber flame, beach wood interior, sexy baby ;)
2007 xc90 49000, Black on Black, family tank. :)
volvomileage
Post by volvomileage »
maybe open up and double check the windows motor,or maybe somethin is blockin in there as far as the motors they go cheap
cheers !
volvo 850 95 sedan non/turbo 185 k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Ozark Lee wrote:I picked a '98 S70 T5 this evening for my daughter to replace her Porsche 944. It was well bought but it has issues.
Sounds like you've got the right wire colors.
I can think of two things that may help...
Good power from the charger? I usually use battery power.
You may want to check with a meter while you try the motor.
And - Was the switch unplugged? Just makin' sure...
That'll mess things ALL up! :lol:
Post by Ozark Lee »
Yea, I unplugged it before playing polarity games on the motor. We used trash sacks and tape to seal the window and it rained all day today so I have not been able to go any further. Hopefully I get some decent weather tomorrow so that I can work on that issue and replace the alternator in the Platinum.
Retired MVS Contributor
Post by Retired MVS Contributor »
They are motor driven and have limit switches at each end...Could be the limit switch, or the moter itself...The panel has to come off...
BEJinFbk
Post by BEJinFbk »
jerrymcc wrote:They are motor driven and have limit switches at each end...Could be the limit switch, or the moter itself...The panel has to come off...
There are no limit switches in these Volvo window systems.
Just the master and local window switches and a motor.
Starting to sound like OL rang the bell and won a bad motor... :(
All I've got left is confirming that you've got good power for your
guerilla rollup test. Thank Goodness for plastic trash bags! :wink:
There HAVE to be limits...Perhaps they are built right into the motor, but they have to be there...If there were no limits and one did not release the button when the window reached fulll open or full closed, power would continue to be consumed and one of several things would happen, the fuse would blow, the gears would strip, the linkage would bend, or the motor would burn out...
The limits might also be software based, but be assured, they are there...
phat78ta
Year and Model: 94 850 turbo wagon
Post by phat78ta »
Being a 12 year veteran of the auto glass industry, I can tell you the limts are purely mechanical. The motor will stop moving when it reaches the top(window up) or the bottom (window down). Most window motors do not have a limit switch, they simply will continue to turn given no resistance. The will continue to draw power as long as the switch is pressed, until the point of thermal overload. That is the only "limit switch" they have.
Lee, Try connecting the jumper wires directly to the motor(where the connector plugs into the motor body itself). I use a drill battery when I am diagnosing a bad motor for customers, it's just more portable. Any voltage will do, I have run motors on 9.7 volts before. :mrgreen: If you have a higher voltage batt(like an 18 volt or better) that would be great. Sometimes a motor will get a dead spot or a slight bind, and a shot of higher voltage will free it up.
93 850 GLT sedan 156K
94 850 Turbo 189K
creepingdeath94
Year and Model: 1999 S70 NA
Post by creepingdeath94 »
Yea, I was just going to say, I have this same problem on my '99 S70. RR window goes down but not up. Replaced the switch on the RR door and still nothing. If I run power from a battery directly to the motor though in either direction, it goes up and down fine. I am going to replace the master switch next as that is all I can think of that could be the problem anymore. It works fine until you reconnect it to the circuit. If it is not the motor, I am guessing master switch. I have seen these tend to be problematic for many others in my research.
