5 sp auto tranny drain and fill question....
C@lvin
Been thanked: 2 times
Post by C@lvin »
How much fluid comes out/goes back in for the 5 speed auto on my 2000 V70? I know for my 98 S70 with the 4 speed it is about 3.25 quarts, is it any different for the 5 speed?
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
'98 S70 T5
2016 Chevy Cruze Premier
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
It is better to do a flush by disconnecting the cooler hose.
Search for the DIY.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Suit yourself but myself and many others recommend the drain and fill method.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
If the fluid has not been changed in a long time, I think initially 3 drain and fills is much better than shocking the system with all new fluid. After the new fluid from the initial drain+fills has had time to clean up gunk and junk through normal use, then I think the cooler line flush is ideal.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
jblackburn
Agreed.
'98 S70 T5
RustyH
Post by RustyH »
My wife's Volvo is a 2000 S70, 5 speed Auto transmission. I do a drain & fill once per year and I get out the same as your 4 speed--about 3 1/4 quarts.
