ETS LITE ON
JRL
- Year and Model: Several
- Been thanked: 16 times
(One post is sufficient)
It could be a bad brake switch, that WILL throw an ETS light
You need to have it scanned at a VOLVO dealer
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
ETS = Electronic throttle system.
It's ok, the board acts up sometimes and posts stuff twice. I did it the other day - I deleted the other one for you.
It wouldn't hurt to clean (or have cleaned) your throttle body. As they get old, gunk builds up on the plate, and causes the electronic throttle units to fail.
This is for an S80 but it's a good video, so the screws he talks about are different, but the concept is more or less the same on the 5-cylinder motor.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
I would take it and get the codes pulled & it will give us a better idea. Autozone/generic scanners will not read those codes to be specific enough to help.
'98 S70 T5
JRL
You really need to go to Volvo with their scanner which is Volvo specific.
It will point you on the right track, then get back to us.
If your car is running as well as it did before, I'm leaning to a faulty brake switch
Yeah, I know, what does an ETM light have to do with a brake switch, hell if I know, but it does!
If Volvo says that is what their reader says you need, buy the part, not that hard to install it yourself
- 16 Replies
- 3042 Views
Last post by precopster
- 9091 Views
Last post by sleddriver
- 14 Replies
- 1687 Views
Last post by loveMy850
- 1588 Views
Last post by befarrer
- 26 Replies
- 7314 Views
Last post by CamsV70
