Hey all,
Finally decided to sell my 98 V70XC Cross Country. Bought an 08 S40 T5 and just dont have the financial resources to own two Volvos right now.
161,000 miles
New Falken tires (maybe 5k on the set)
New Timing Belt/Water Pump/Tensioner/Pulley etc (the whole thing)
New Passenger Side Front Window Regulator
New Interstate Battery
K&N Air Filter
New OEM Bosch MAF sensor
Replaced all the burned out little bulbs in the dash/radio (except the cluster).
Tinted all around
New Right Front Spring Seat
Cold A/C and great working heat.
Trans. Fluid Flush
Coolant Flush
Things that need doing:
Left front Spring Seat
End Links (will be done next week)
Oil Trap needs to be cleaned out/replaced
Blows cold A/C but goes out occasionally (tracked this down to the fact that the clutch needs to be re-shimmed)
Rock chipped drivers side headlamp lens.
Leaks a small amount of oil (what volvo doesnt?)
Ive owned this car for a year now and have a clean carfax and title in hand. Runs and drives fine, has taken us from Jacksonville, FL to Atlanta, Savannah, Orlando, and St. Augustine many many times. Comes with original manual and two keys (no remotes). This car is great for a Volvo enthusiast who has the time to play with it. I simply dont have the know-how to fix some of these things, most of which are just worn out parts. Interior is in good condition, leather is great except for passenger seat bottom (surprise!) which is cracked but NOT horrible, and I've definitely seen worse. I've replaced the pax side lower dash bolster and all of the broken buttons (headlamp switch, dome light switch).
Im asking 4500 or best offer, it is an XC, these are desirable cars. Make an offer.
Photos below:
http://smg.photobucket.com/albums/v477/bobo2196/Wagon/
Thanks,
Robert // Jacksonville, FL
98 V70XC -- Blue/Tan
jk1145
- Year and Model: 1996 Volvo 850 GLT
Hi,
I'm also in Jacksonville, currently own Blue 96 850 Sedan. Originally I wanted a wagon, but couldn't find one. I've been searching again as I want to add a wagon to my driveway. Do you have the third row in this?
Thanks!
Justin
Thanks!
Justin
1996 Volvo 850 GLT[img][img][/img][/img]
