hi
trying to figure out my 850 moonroof (making noise but not moving)
and it is sitting uneven, front to rear and side to side, but not leaking.
i figure I will have to give her some force to even her out, but it would really help if I had an idea of what a working one looks like, so I go in the right direction!
Thanks
Could someone post pics of how an 850 moonroof sits?
JRL
- Year and Model: Several
- Been thanked: 16 times
DON'T force anything.
For it to sit lopsided you have a broken track or guide inside, you only will make things worse by trying to force it
it is most likely a broken mount, but it could just need adjusting, or loose.
in any case, you can remove the two plastice covers by the tracks, and find the screws there.
the covers pop off very easily, but better with the glass in the vent position.
i posted a link below showing how to access that area.
adjust, or replace, if needed.
i changed mine out, am i am in no way mechanically inclined.
https://www.matthewsvolvosite.com/forums ... 0393#30393
thanks.
I am admittedly intimidated by the darn thing. She won't vent, just kind of jams back and forth when I try the motor. Something is definitely derailed.
Guess I will have to start taking her apart and figure it out.
Sure would be nice to have her in use with the hot weather!
- Year and Model: Many Volvos
- Been thanked: 76 times
Once your remove the glass you will see that the mounting points are on slots rather than holes - that is where the adjustments are made to make the glass flush with the roofline.
AH! I'm also in need of this.
About two months ago, I was opening my moonroof and accidentally went to vent when I really wanted to open it completely. I switched the direction to lower it and now it's stuck. It only partially vents on the driver's side (passenger side stays closed) and it simply will not open.
- 1831 Views
Last post by BollWeevil
- 1832 Views
Last post by Ozark Lee
- 675 Views
Last post by volvoinrome
- 2056 Views
Last post by smileyboy
- 421 Views
Last post by darrylrobert
