replacing Pedal Position Sensor
sjr2531
- Year and Model: 1998 saffron V70R
When i replace this part guy's, will i need to take it to the dealer for reprogramming? it's for my 2002 s60
2002 s60 T5 manual 98,000 miles
(R.I.P 12-26-2010 112,000 miles)
1998 Saffron V70 R 109,000 miles
"My Precious"
"My Precious"
sjr2531
It's attached to the actual pedal with a plug in and a couple of bolts. the part i saw was $528.00 (us) and was the whole setup with pedal and everything. my Volvo popped generic code p2127 and displayed engine system service required light. car went into "safe mode"/ " limp mode" and limited my speed and rpm to 2-3k and basically 60mph. First real issue in the first 100k miles other than the alternator @ 73k miles. This has been an intermittent issue occurring twice and returning back to normal after parking and letting it sit over night. Still, there is something wrong.
"My Precious"
"My Precious"
Just a thought, this sounds like it might be the failing ETM that may be covered under extended (10 year / 200,000 miles) warranty, see the ETM forum here... https://www.matthewsvolvosite.com/forums ... php?t=5694
cheers, j
cheers, j
2001 V70 T5
hey did replacing your sensor make the issue go away? I'm having the same problem. A shop changed my serp belt ac comp and pulleys, but no my s60t 02 has no real pickup and will slowly crawl to 60+ mph but i have no pickup. Driving around town its ok.
- Smarzig
02 S60T 17"rims
02 S60T 17"rims
For this issue mine wound up being the pedal sensor that the dealer nailed down and fixed.
I finally have pickup. Weird that it went after my belt snapped and I had it replaced along w. the ac comp/pulley....
- Smarzig
02 S60T 17"rims
02 S60T 17"rims
- 5172 Views
Last post by Raindog92
- 5298 Views
Last post by precopster
- 7245 Views
Last post by zjevik
- 3834 Views
Last post by Goldchemist
- 15 Replies
- 19094 Views
