1993 940 Estate B230F acceleration hesitation, bogging
Schumi 1
Year and Model: 1993 940 Estate
Post by Schumi 1 »
Hello all,
I have been searching for information about "hesitation on acceleration" in an attempt to diagnose a problem with my 940.
The Problem:
Well maintained, primarily commuter highway driven 940 Estate developed engine bogging in "stop and go" city traffic.
The symptom only occurs after and during prolonged city stop and go traffic. When driven short distances, this symptom does not occur at all.
The symptom is; When at full stop or rolling stop/running at idle when gas pedal is depressed and acceleration is called for, it seems to be accelerating/starting in 3rd gear instead of 1st or 2nd depending on speed. After about 10 seconds even if pedal is "floored" it seems to engage the correct gear or fuel is now at proper delivery, and normal acceleration and shifting resumes at speed.
There is no rough shifting or transmission noise when displaying this symptom or when not, it is more like the clutch is slipping. The tachometer seems to be displaying the correct RPM's when in its relative gears at all times. Does not stall
It is important to note that this hesitation on acceleration does not happen at higher speeds or during highway driving and the "passing gear" engages normally. There has been no improvement or worsening of this problem over 9 months of driving and with all the repairs listed below. Also, this bogging only occurs [u]after[/u]and during driving in stop and go "hot" traffic for an extended period of time. Once car has been parked and "cooled down" this symptom is not present again until above driving conditions are encountered. Again if car is started up and operated at high speed , or even in very hot weather on the highway, this symptom is not present. So my (and several mechanics) attention has been on fuel and air intake system's. This has not fixed this problem. The injectors and throttle seem to be clean and operating normally.
Only a few small things left to check but now I am starting to think about the transmission, clutch and throttle pedal linkage unless someone has any other ideas..
No check engine light , and no codes, all clear so far...
Current notes :
Cold start is a bit touchy sometimes if the car has been sitting a while(days), warm start is instant. Idle is a touch rough in park but not in drive or neutral since I cleaned idle air control valve , still above 500rpm and doesn't stall out, cleaning seemed to improve power a bit.
Thanks in advance for any ideas and sorry for the long posting but I thought the more information the better since this has been a very mysterious problem. Devoted Volvo owner (previous 1988 740 R.I.P cracked head gasket , 290,000 miles) and my 1984 240 which odometer stopped at 320,000.. Hope my 940, can pass those gems.
Background information:
1993 940 Estate with B230F "[u]Regina[/u]" engine
149,000 miles (primarily highway miles)
Work performed all in the last year (none of which has affected/solved my problem so far):
Replaced "in tank" fuel pump with new unit. (original failed at about 120,000)
Replaced in line fuel filter.
Replaced all spark plugs.
Replaced 4 ignition wires (set), minus the coil wire as it was still in good shape.
Replaced 3 drive belts , minus camshaft drive belt (no reason to assume in need of replacement?)
New catalytic converter.
New o2 sensor (not sure if 3 wire correct voltage or aftermarket splice in, regardless , no effect on problem before or after)
Cleaned throttle body.
Replaced fuel pressure regulator (Bosh).
Replaced air box thermostat.
Replaced air box filter.
Cleaned and confirmed proper function of idle air control valve.
Cleaned flame trap hoses and plactic flame trap.
Checked inlet air temperature sensor ([u]Regina[/u]) appears clean.
Checked all above electric connections for corrosion , all seem good.
Checked fuel pump relay module (drilled holes in cover for heat venting) works properly.
Checked all air intake hoses for vacuum leaks and cracking , all seem in good shape not leaks.
Added STP complete fuel treatment to full tank, ran through.
All pumps and cooling system working properly, engine operates at normal temp even in hot traffic or highway with a/c.
Not checked yet :
Knock sensor (although electrical connection is clean)
Pressure sensor/ "MAP "(not MAF) for [u]Regina[/u] , to be honest , don't know what it looks like or where it is. someone please post a photo ?
Throttle position switch (need adjustment ?)
Cold start injector. (don't know if it could be related)
Carbon canister (all hoses seem ok)
Heated oxygen sensor.
Transmission and/or Clutch (fluid clean and not leaking)
Throttle pedal linkage and cables (seem ok though)
Camshaft belt, pulley's, timing, etc.
Ignition HT coil (no reason to think it is related ?)
bau321
Year and Model: s70 1998
Post by bau321 »
Hi there,
I am having the same issues, what did you find was the problem?
Merely guessing I was thinking fuel pressure regulator, or necessary fuel injector cleaning as I have not had it done since purchasing the car few months ago with 216k, now at 221k. ( The cars oil was way overdue so to think they would be on top of something like maintaining fuel injectors would.. probably be a long shot)
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Schumi 1 wrote:accelerating/starting in 3rd gear instead of 1st or 2nd depending on speed.
Volvo says, 1 9 8 9 VOLVO 240
Capacity: 7.8 US qts (7.4 liters)
Fluid type: Automatic Transmission Fluid type Dexron II D.
Replace: every 20,000 miles (32,000 km).
A Cold transmission: oil temperature = +105° F (+40° C).
This is a normal temperature for the transmission after idling for about 10 minutes.
At oil temperature below +105° F(+40° C), the level may be below the MIN mark.
B Warm transmission: oil temperature = +195° F(+90° C).
This temperature is obtained when driving for about 30 minutes.
At oil temperature above +195° F(+90° C), the level may be above the MAX mark.
Note! The engine should be idling when checking transmission fluid level.
Check the oil level as follows:
Park the car on level surface with the engine idling.
Slowly move the selector lever through all the gear positions and then to position P. Wait 2 minutes before checking the oil level. As the illustration shows, the dipstick has a "Cold" and a "Warm" side. The oil level should be between the MIN and MAX marks. Wipe the dipstick with a clean cloth.
