how can you check a fuel pump relay and what colour is the relay
where is it located
how to check a fuel pump relay
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You will find two or three relays, depending on equipment fitted to your car, up under the dash on the driver's side behind the fuse panel. The fuel pump relay is on the right, probably black in colour but sitting in a white base. A quick test without dismantling anything is to put your finger on the relay and switch the ignition on. You should feel a click from the relay.
Have you checked that fuse #13 is OK?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 5061 Views
Last post by wizechatmgr
- 11 Replies
- 2708 Views
- 16120 Views
Last post by Richard99
- 19 Replies
- 9487 Views
- 17 Replies
- 7645 Views
Last post by cn90
