hi,
About 2 weeks ago i got the check engine light on my 2002 Volvo s60 2.4T AWD.
it eventually went off and when the shop checked the code it seems i'm looking at a P0014 and P0016. The guy said on both cases it's the sensor on the camshaft and on the crankshaft.
said the whole deal is going to cost me about 380$ from which 155$ just the labor. I live in Spain so prices can be totally off but but i'm asking because one hour in Spain should cost about 40-50$ and just wondering if these sensors are hard to get to and replace. will it take him 3 hours to replace those?
Does this seem right?
Also, i'm broke this month so the car is just going to have to wait. can anything happen if i go like this for about 2 more weeks? what's the worst that can happen?
thanks,
Cristian
check engine light code P0014 and P0016
the_brain3000
- Year and Model: 2002 S60 2.4T AWD
igel513
- Year and Model: 2003 S60 T5
- Has thanked: 1 time
MY 03 S60 cam.pos.sensor could be found above bell housing under camshaft and right under the top mounted engine dampener/or whatever its called. It is attached by a 10 mm head bolt. Use a 1/4" drive socket to remove. It's a tight space so unplug socket b4 loosening the bolt. It cost U$68 here. I'm not sure if the other sensor by the bell housing is the crank.sensor
- 13613 Views
Last post by steveatlast13
- 5704 Views
Last post by Mike Langlois
