Subframe O-Ring Confusion
240S80
Year and Model: 99 S80
Post by 240S80 »
This may seem obvious to some of you, but I've not been able to find the answer.
I bought the rear subframe o-rings and bolts to fix the clunking in the front end of my 99 S80. When I lowered the subframe, I saw that there was already an o-ring on each side of the rear subframe, and they were in great shape. This could mean one of three things:
1. The o-rings have already been added by the previous owner and I don't need to do anything else
2. I should replace the existing o-rings with the new ones
3. I should add the o-rings to the ones that are already there, so that there will be 2 stacked on top of each other.
Not sure what to do here, but I suspect number 1. Is the procedure in the service bulletin written from the perspective that the o-rings were never there to begin with?
