SAS removal walkthrough(No CEL!)
This topic is in the MVS Volvo Repair Database » Project: 850 engine replacement woes (& Updates)
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
Here you are people after a bit of revision and suggestions from people this is my latest version of the how to.
- Jesse
EDIT Groupthink here at MVS and Volvospeed points to A32-37, not A32-B38! The image directly below is incorrect in this regard.
A32-A37, not A32-B38!
Moderator Edit:
Albeit a bit blurry, this is correct.
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
My daughter came home griping about a P0410 the other day and the car sounded like a Cessna Citation running down the taxiway. This sounds golden since we don't smog cars in this neck of the woods. Even if you did smog a car I don't see why it wouldn't work if it shut off the CEL / Lambda light and the car was hot when you took it in.
Added to the repair database.
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
Does this mean that the check engine (DTC P0410) re: SAS prob. will no longer appear once this procedure is done? Currently I
have this DTC on my car. I replaced the SAS valve 2 yrs. ago so could it be bad again. Checked all the vac hoses and found no
cracks or disconnected tubes. Will do more test then report back here.
IVIUSTANG
Post by IVIUSTANG »
Yes, this does get rid of the P0410 code completely.
- Jesse
Glencoeteen
Year and Model: 00 V70R
Post by Glencoeteen »
I am going to attempt to do this mod soon, my Tags expire here in the next couple months and i am tired of clearing the code. so wish me luck :roll: IVIUSTANG- Love the year and Color of your T5, funny thing is my 98 T5 is the same color also! even have the spoiler. Found out the color is pretty rare for volvo... :mrgreen:
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
IVIUSTANG
Post by IVIUSTANG »
Yeah, I love it as well. All my friends make fun of me and call it pink though! Good luck with this, I haven't thrown a code since!
- Jesse
Glencoeteen
Well I just finished as we speak... so far it looks like i did it right. first time ever soldering too! anyways Radio shack has never heard of the 1n4003 but they had plenty of IN4003 which as 99cents U.S for two! so i am going to go out and install the ECU and pray it runs! :?
98 V70XC~ Sold
mjmoore
Year and Model: 1998 S70 T5
Post by mjmoore »
Did this 1 day ago. So far no check engine light and the car is running great. Hoping for another good year of Volvo driving.
Thanks.
mjmoore
Post by mjmoore »
Check engine light came on after 2 days. Had the codes read and found the SAS fault code. So this is not working for me. Any suggestions?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I did not look super carefully through everything in the linked pdf, but does it say to use pins A32 and B38? If so, there is the problem - those are the wrong pins.
SAS delete requires pins A32 and A37. Go to the source where this was figured out, the instructions are crystal clear on the two ways to do this right:
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
