Heater core nightmare = coolant carpet. What is the best way to clean it from the carpet without removing the carpet?
I've read that water would help remove the coolant combined with a wet shopvac, but then the floorboards would eventually rust.
What about soaking the carpets with rubbing alcohol and then shopvac'ing it all out?
Cleaning coolant from carpet
v70snowbum
- Year and Model: V70, '99
JDS60R
- Been thanked: 3 times
Water works fine - shop vac it out and put a fan on it or keep the windows open for a few days while parked. Running the AC will also help evaporate the water out. I like to mix a little simple green HD (purple in with the water).
You could use alcohol if you wanted but its overkill
Retired
v70snowbum
I just assumed the floor boards would eventually rust out if you cleaned the carpets with water. PS. there is a TON of coolant in the carpets.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If there's a lot down in there, you'll have to remove the carpets and the padding and let them dry.
I'm not sure how it is all laid down in the Volvos, but I left the window down in my old car & it started to grown mold. As far as I could tell, it was all laid down in one section, so I cut a seam under the seats & removed the carpet and took it to a laundromat and cleaned & dried it. That worked beautifully actually, and it wasn't visible to someone not looking for it.
'98 S70 T5
2016 Chevy Cruze Premier
C@lvin
- Year and Model:
- Been thanked: 2 times
I had the same problem 3 years ago. I didn't remove anything but I blotted as much as i could multiple times over several days. A shop vac sounds like it would be very helpful, but i don't own one. I also peeled back the carpet from the console as far as I could to work on the padding and let it air out. It literally took months for it to completely dry out and there was a stain left over. It doesn't bother me now - the Volvo floor mat covers up the stain - but if I had to go through this again (number one is I'd avoid the coolant spill) I would seriously figure out a way to remove the carpet and padding and clean and dry it outside the car
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
I think this is not a great thing to clean carpet with water because i cant do that kind of job with my own. When i visit to service station then ask for cleaning my whole car interior as well as exterior parts. They provide me carpet cleaning services also with car wash or they refuse to do that then i want to call professionals they come at my place and giving commercial carpet cleaning services under budget.
- Has thanked: 1611 times
- Been thanked: 4072 times
I removed the front seats, pulled the carpets and used copious amounts of water from a hose to get the coolant out. I cut the foam padding and rinsed that out too. I reinstalled the foam with duct tape.
T5AUS
- Year and Model: 08 XC90V8 94 850T5
Just be very carful not to spill any coolant on the outer door sill body work, I made a mess of mine when sponging it out, lethal stuff on the paint work !! To do it properly it really is best to lift the seat and carpets out if it's a full dump, that's a lot of coolant.
1994 850 T5
2001 V70 T5 (Sold)
2008 XC90 V8
2001 V70 T5 (Sold)
2008 XC90 V8
- osman
- Year and Model: 2002 c70 hardtop
I bought an s70 that had a heater core leak. I did a heater core bypass, removed the front seats and console, removed the carpet (front and back pieces), and the padding (which I threw out, but it is the same multicolor, piece foam padding that is used in homes.) While the carpets are out, remove all the coolant residue from them with soap and water, dry them up, and the floorboards, and reinstall. When i finished you couldnt tell that at one time there was an inch of coolant sloshing around in the car. Trust me if you dont remove the padding it will hold all the moisture in it, (thats why the carpets probably already seem dry) and the padding will mold something awful then once that smell gets in the headliner, vents, and seats, you will not be able to remove it.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
The rust prevention in a Volvo is impressive and I wouldn't worry about this. I filled the floor pans with water several times to remove the puddles of standing coolant I had when my Heater core went. I dried it in the hot sunny weather, using the windows up test to mark when all the moisture was gone.v70snowbum wrote:I just assumed the floor boards would eventually rust out if you cleaned the carpets with water. PS. there is a TON of coolant in the carpets.
- 1385 Views
Last post by bmdubya1198
- 16 Replies
- 2620 Views
Last post by MrAl
- 3441 Views
Last post by SuperHerman
- 5850 Views
Last post by gobies
- 28 Replies
- 4783 Views
Last post by j-dawg
