95 850 ABS malfunctions
Autobahn Garage
- Year and Model: 98' V70xc
First off, read the fault codes and see what the problem is. Fix the problem don't just disconnect the ABS. Repair the problem don't hack the car. There are many write ups in the repair section of the board. Let us know what the codes are we can help. Best of luck
- Year and Model: Many Volvos
- Been thanked: 76 times
On a '95 you won't lose the speedometer. Yank the codes from A-3 and post them back.
The early model ABS systems can fail but it is rare. The good thing about that is that you can buy the whole system cheap on ebay since there is so little demand.
confused_al
- Year and Model: 1996 TLA wagon
I would, then see which one comes back.duane wrote:Do I reset it now???
BTW, here is the code library:
https://www.matthewsvolvosite.com/forums ... hp?t=10758
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
confused_al
111 means no code, light on? Have you drove a bit after reset?
This is from service manual:
"When ignition is turned on, control module activates warning
indicators on instrument panel and performs an initial diagnostic test
which ensures there are no internal faults in control module. At same
time, main relay portion of combination relay is activated so
hydraulic modulator valves are supplied with power. See Fig. 1.
Control module then checks operation of valves by activating them in
sequence.
If no fault is detected, warning indicators go out about 2
seconds after engine is started. When vehicle is driven, control
module checks that it is receiving signals from wheel sensors. At 20
MPH, it checks that hydraulic pump is operating by activating pump
relay so pump is started. This is confirmed by a signal from rotation
sensor. In addition to the initial diagnostic tests, control module
continuously checks that all signals and components are operating, and
there are no internal faults in control module."
sequence.
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 1262 Views
Last post by charlie44nike
- 1452 Views
Last post by tsteenka
- 27 Replies
- 14337 Views
Last post by Orchid70
- 19 Replies
- 3746 Views
Last post by sak54757
- 6059 Views
Last post by misha
