I have a 2000 S80 T6 with 118,000 miles and it is due for service. I plan to do the oil/filter change, engine air filter, cabin air filter, and spark plugs.
I there a link for the Maintenance Schedule and what needs to be done?
Also how do I reset the service engine light?
Thanks
S80 T6 Maintenance Schedule
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Here are two links: This one takes you up to 90,000 miles.
You are then referred to the warranty book for further services.
To reset the service light: Press and hold the trip reset button. Switch the ignition ON. Keep the trip button depressed until the service light starts to flash (approx 10 seconds). Release the trip button within 5 seconds of the light starting to flash. There will be an audible signal when the reset is complete. If the trip button is not released within 5 seconds the service indicator will not be reset but will stop flashing.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
00_Coupe
- Year and Model: 2000 S80 1998 S90
Besides the obvious plugs, wires, oil filter. I believe this car needs timing belt service every 100K minimum which includes, water pump, idler and tensioner. There are so many engines that have failed because of this its unbelieveable. Another thing to do is flush your transmission fluid. This is a cheap and easy task, since you use plain ATF Dextron III
For the cheapest Volvo parts I order everything online from Tasca Volvo
- 654 Views
Last post by oragex
- 1163 Views
- 906 Views
Last post by EngineeringBloke
- 1124 Views
- 11027 Views
