1987 Noisy Blower motor
This topic is in the MVS Volvo Repair Database » Paint My Turn Signals and Headlights
I Roll
Year and Model: 1987 245
Post by I Roll »
My heater fan is making a screeching noise. I think just a little spray on grease would make it stop. Is there any way to get some into the bearings without tearing half the car apart?
oughorian
Year and Model: 850 1996 wagon
Post by oughorian »
Lubricating a worn bearing or bushing will not solve your noisy blower problem because of its age it might remain quiet for some time but not for long, my recomendation is replace the blower and save your time I did lubricate not my Volvo's fan but several other like fans with no long lasting result.
Retired MVS Contributor
Post by Retired MVS Contributor »
Replacing the blower moter is the answer because it will only happen again, but the dash has to come completely apart, glove box, cluster, ducts, etc...The motor is totally enclosed within the heater unit and is inaccessible until the heater box is disassembled...There is no squirrel cage, there are two big (about 8 inch diameter) finned wheels, one at each end of the blower motor shaft and they prevent you from reaching the bearings......BIG job...Been there, done that...Sorry...
I Roll
Post by I Roll »
Thanks for both replies. This is a hard one to swallow. This truth hurts!!!!!!
I Roll wrote:Thanks for both replies. This is a hard one to swallow. This truth hurts!!!!!!
Yup, tell me about it...It is possible to do it yourself if you are ambitious and have a free weekend...Hint: before you disconnect anything put a masking tape tag on it and on it's mating connector with an arbitrarily selected number or letter so that you can reconnect everything properly...
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I Roll, welcome to Matthew's Volvo Site.
As you have gathered it isn't a five minute job.
This should help.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
VOLVO is Swedish for "I Roll"...Very clever!!!... :D
Bill gave you a great repair lead...The 240 in the article was an '84...I remember having to do the cutting mods in my '77, but not in the '86...I think it was taken care of in production when Volvo changed the motor they used...The motor in the "77 was an open frame motor with brushes protruding onto the commutator on arms...They had moved sideways and jumped off the commutator...
I Roll
Post by I Roll »
This is too much fun! Bill's picture of all the parts laid out on the lawn pushes me closer to rehab. I drilled holes into the fan housing today and found out that you all weren't lying. I sprayed some grease in there anyway- what harm could it do? On the right side I moved the hole higher ( will gravity help?) Covered the holes with duct tape. I don't mind experimenting. Maybe I'm an idiot. What a great car this has been, but I'm getting sore on my knees, i might just sell her. I'm I Roll.
Can't blame you for trying...HOWEVER!!!...The bearings in the motor are floating "oilite" bushings and need light oil, not grease...Since you did a boring job, try spraying WD-40 in there with the supplied straw, it will be better than grease...Try hard to hit the motor shaft...
billofdurham
.....and it may stop squawking for a week!
However, against all the odds I stopped my 850 motor squealing by getting some silicone based oil into the bearing 4 years ago but that one is easy to get out so I could hit the right spot.
Bill.
Previously:
