Hi! First post.
I have a 2001 S80 with no major modifications from factory standard. A few weeks ago, the check engine light came on and I noticed a little loss of power when accelerating from a stop. I took it to a local mechanic, he replaced my spark plugs, and the light went off and the acceleration problem went away.
Then, a few days later the check engine light came on again. I returned to the mechanic, but he could find nothing wrong. I needed to travel, so I put 1000 miles on the car with no problems...except that the check engine light wouldn't go away.
After successfully returning from my trip, I was driving on the highway when the air guard fell off from under the car. It was stuck to something on the undercarriage, so I pulled it off and stuck it in my truck for the rest of the ride home. Interestingly...after I got back in the car the check engine light went off! It has been about a week and the light has remained off, and I notice no problems with acceleration.
So, my question is...can the air guard effect the check engine light? And, since the problem seems to be fixed, should I replace the air guard or just leave it off? Thanks for any help!
Air Guide (skid plate) effecting Check Engine Light
IceScrewball
- Year and Model: S80, 2001
2001 S80, 112k miles - my current vehicle
1994 850, 185k miles when sold 2 years ago - still on road!
IceScrewball
Forgot to mention that the part number for the air guide that fell off is: 8620124
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It has nothing to do with it. That code was for something else that is now "ok", and therefore the car turned off the light after it no longer noticed the condition through several drive cycles that it was angry about in the first place.
It may yet come back - if it does, have the code read and come back with your numbers, and someone here can help you further.
As for the air guide, it both helps to protect some of the components in the "belly" of the car from things on the road and curbs. I also noticed it helps with gas mileage and engine cooling - you may be able to hang it back up with the use of zip-ties or just some rope through the mounting holes.
'98 S70 T5
2016 Chevy Cruze Premier
- 624 Views
Last post by 850forum
- 9195 Views
Last post by IronMike
- 18 Replies
- 3124 Views
Last post by Cookeh
- 2338 Views
Last post by MadeInJapan
- 20 Replies
- 11756 Views
Last post by Brumbachjohn
