Hi All,
My car was in for it's annual inspection and I noticed the driver side rear rotor had corrosion on it while all the others are clean and in decent shape. The Rotors all around are about 3 years old and the fronts were rebuilt about 2 years ago due to leaking. Has anyone had their rear caliper go bad and if so, did you replace it or rebuild it? I'm a grad student on a budget and I could do either myself but I would like to fix it correctly.
Any thought?
Thanks,
Eoin
93 GS850 Rear Brakes
DCintraining
- Year and Model:
The calipers can sometimes be freed up by working the the pistons back and then applying the brakes. It is best done by removing only one pad at a time on each caliper. It will probably take 5-10 cycles per piston
- 5268 Views
Last post by vtl
- 1651 Views
Last post by Glencoeteen
