Windshield Washer check valve repair
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
This is a small thing because you can buy a new check valve for the windshield washer for about $2 or $3, but you might not have to. My check valve was allowing fluid to shoot out of the top of the valve. I removed the valve, pried off the red lid, and found a deteriorated rubber gasket inside. I used a piece of a new rubber glove as a replacement. You just clip the new glove in with the red lid, and then trim the excess rubber around. I reinstalled it and it has been working fine so far.
- WiperCheckValve1.jpg (122.87 KiB) Viewed 4996 times
- WiperCheckValve2.jpg (94.36 KiB) Viewed 4996 times
- WiperCheckValve3.jpg (88.06 KiB) Viewed 4996 times
broadusc
- Year and Model: 2000 V40
- Has thanked: 2 times
I bypassed the check valve a while back after having broken it during diagnosis. Now that I'm replacing my pump and have a new check valve, it's been so long that I have forgotten which port the "in" hose goes to. Can you remind me?
- jreed
The in hose is connected to the L shaped fitting that goes into the bottom of the check valve. This is the end opposite the red plastic cap that you pry off to replace the diaphragm.
- 11 Replies
- 3055 Views
Last post by 454cid
- 15 Replies
- 8911 Views
Last post by volvolugnut
- 36 Replies
- 25017 Views
Last post by StickyPocket
- 531 Views
Last post by ZionXIX
- 4489 Views
Last post by eyerollXC70
