Just replaced 92 960 radiator.Everything holding liquid. So all ok. Starts runs; not getting hot.
But when the key is on, either to start or just in ACC, none of the dashboard warning lights turn on, just when they should all be on. When started , the seat belt warning light comes on for a few seconds.
Tried the lights- fine. The radio wanted the code, as if it had been disconnected.
Any clues ?
Also checked fuse and noticed nothing in the slot for SRS, and no amperage specified on the chart. What should be there?
No warning lights
I had an ignition switch go south last year and I was getting all kinds of weird problems. When you have the key in the ACC position, if you wiggle the key around a bit, front and back, do any of your lights come on?
I'll see if I can't find the correct fuse rating for the SRS
Darrell
Darrell
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
+1 on checking the ignition switch.
If the 'fuse' in question is at position 5 in the box it doesn't have a fuse, that is the SRS test socket.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
pgregston
- Year and Model: 92 960 wagon
Thanks Bill.
Today the key turn produced all the lights functioning.
Three cycles of start drive and park were normal. Fourth start - no lights.
The speedo acts up when the lights are on, indicating 45mph when parked, but normal when driving. When the lights aren't on, it operates as expected.
Wondering where the ground is for the warning light panel or their controller.
Any pointers?
Any pointers?
- billofdurham
The instrument panel earth (ground) is behind the right side kick panel.
Bill.
Bill.
Previously:
Previously:
- 3463 Views
Last post by BEJinFbk
- 15 Replies
- 6594 Views
Last post by neworleans
- 15 Replies
- 4284 Views
Last post by Eastema
- 1511 Views
Last post by jimmy57
- 12 Replies
- 1857 Views
Last post by erikv11
