Radiator cap pressure question
I recently had my radiator replaced and I after a couple days I would smell coolant but there wasn't a leak. The next time I smelled it, I looked under the hood and noticed the reservoir was making a hissing noise and saw the coolant boiling. The smell was the vapors coming from the radiator cap on the reservoir. I don't see a leak anywhere and there doesn't appear to be a change in the amount of coolant Is this normal?
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
change the cap and see what happens. i think theyre pretty cheap...like 8 bucks or somthing.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
- 509 Views
Last post by Ozark Lee
- 3660 Views
Last post by t3yf5g
- 7206 Views
Last post by jalwlb
- 285 Views
Last post by volvolugnut
- 2338 Views
Last post by fitz548
