a repeating knoking and metal on metal sound coming from under the engine. Did i blow a bearing or two ?
i had to drive with low oil pressure and the result is trouble. I've invested alot of money and time this far so Is it still worth fixing ? If so, how do I fix this ?
is a blown bearing worth fixing ?
alpineturbodriver
- Year and Model: 940 Turbo 1993
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The shop time for replacing all main bearings is 6.5 hours. Bearing sets will run at about $100.00. It isn't a job for the faint hearted, especially if it is a first time engine strip and rebuild.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
alpineturbodriver
Well that's what i needed to hear, gotta go to the dealer ....
- billofdurham
You won't find many on this forum who would advise this.Well that's what i needed to hear, gotta go to the dealer ...
Most shops can fix the older engines but lummert's suggestion is worth considering.
Bill.
Previously:
Previously:
alpineturbodriver
Indeed a used engine replacement through an independent volvo specialist is the route I've choosen to go.
In fact none of the regular auto repair shops I called would even do this work without the special tools and experience !! I'm lucky there is a volvo guy 1 hour from me who will do it.
Thanks for all the commments, wish me luck !!
- 15 Replies
- 7667 Views
Last post by wizechatmgr
- 22 Replies
- 12716 Views
Last post by j-dawg
- 2803 Views
Last post by eapowers64
- 26 Replies
- 4641 Views
- 4956 Views
Last post by crazycat
