2000 Volvo S70 (Jerking during acceleration)
My Volvo is a 5 speed automatic and it has been jerking a lot recently during acceleration. It is fine off a cold start but after driving awhile it will start to jerk, around 10-45 MPH and on the freeway when I go 70 I can feel it slightly jerk. Does anyone know what is wrong with it? Any help is appreciated!
My '96 Tacoma had that jerking problem and a new Throttle Position Sensor completely fixed it. The TPS sits on the throttle body, it's just held on by two 7mm screws, pretty simple to put a new one on yourself. A brand new one is around $220 or so, but you can find them at pick-a-part, etc...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
There is no throttle position sensor on a 2000.
Is your ETS light on by any chance? Transmission light flashing? Check engine light on?
Start with the simple things...how old are your spark plugs? Are any of the coil packs visibly cracked?
'98 S70 T5
2016 Chevy Cruze Premier
mikennedy12
If none of this works, check your mass air flow sensor. Mine went about a month ago on a 98 s70 and my car hitched and jerked while accellerating as well as idling rough.
jblackburn
The quickest test for that is to simply unplug it and take the car for a drive.
It will set a code and turn on the check engine light, but it can easily be cleared with a scanner.
Sometimes the sensors can be cleaned with MAF cleaner spray; sometimes they just outright die like mine did without warning.
'98 S70 T5
jblackburn
Yep!
'98 S70 T5
- 15 Replies
- 7226 Views
Last post by WarbirdPilot91
- 1370 Views
Last post by sbattaglia
- 1653 Views
- 27 Replies
- 3600 Views
Last post by precopster
- 830 Views
Last post by Go Metric
