2002 Volvo S80
It is not a bad job. You have to remove the black shroud that is in front of the instrument cluster. There are 2 torx screws on the top and 2 on the bottom. Then you remove the instrument cluster itself. There are 4 torx screws, one at each corner. Be careful not to drop the bottom 2 when removing. Then the cluster will pull forward. The bulb is in a plastic twist piece right behind the odometer. I think the dealer got $6 for the bulb and the plastic piece or you could buy the bulb for $2 onilne and reuse the plastic. I got the part from the dealer and was done. It took about an hour start to finish including trip to dealer.
Good Luck
DrDootz
Good Luck
DrDootz
- 729 Views
- 1585 Views
Last post by SuperHerman
- 1319 Views
Last post by Volvo S80
- 2574 Views
Last post by chrism
- 703 Views
Last post by Top Notch
