dstc service required Topic is solved
teovolvo
Post by teovolvo »
When I turn on the ignition key , for a couple of second I get the message "dstc service required" and after that it disappear. The dstc service seems to work fine.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Dynamic stability and traction control (DSTC) uses sensors to check wheel speed. If it's like the 850/S70/V70, the sensors can get gummed up with road debris and dirt and cause an error to trigger. I'd look at your problem from that angle.
Sorry, I don't know what/where the sensors are, but if you see a wire running to something around the inside of the wheel, chances are it leads to a sensor.
Also -> Amazon link
