I own a 2000 S80 T6 - no sympathy please - I should have read some of these threads before buying this beast - but it's mine now and I'm trying to enjoy it until I can sell it....
I'll spare you all of the details, but after two blown turbos, new brakes, struts, and tie rod ends - I am now struggling with an "abs module" problem.
My story starts out like many of yours - intermittent Brake Failure - Stop Safely ASAP warnings, along with check engine and brake light flashes....once they started staying on all the time, I started researching what can be done about it and what the culprit might be. In all my research, most of the thoughts pointed towards a bad ABS module and that there are several reputable folks who can repair them. Turns out, after being rejected by 3 rebuilders - I have the DSTC module (2% of these ???) and it can't be rebuilt??? As a result, I purchased a refurbished module and installed it. Same problem persists - dash board lit up like Christmas.
I did have new tires and brakes installed and this problem may have started shortly after this. I've been dealing with issues for over 2 years and the darn car spends most of it's time in the garage...can't recall the order of events.
I think I had a bunch of front end work done -tie rod ends, sway bar linkage, struts, new tires on all 4, rear brakes, etc. This was all done in August/Sept 2008. My first inquiry regarding a bad ABS module was in November 2008. Any thing sound suspect here?
I have heard some say it could be wheel speed sensors - not exactly sure how to check them - can I hook up an ohm meter to them to check for continuity?
Anyone need the refurbished ABS module I purchased?
Anyone have any direction for me at this point? Ideas?
Next stop - the driver's door lock actuator is now bad....
Thanks to anyone who can provide some self help direction on this thing.
Regards!
Craig
S80 T6 ABS Module Issues - Help?
When the C30 & S60 Went Racing
The last time someone posted with continuing ABS messages after replacing the ABS with a rebuilt, I suggested checking the plug into the ABS module. That turned out to be the problem. Were I you, I would check for bent/corroded pins and a clean,tight electrical connection. I doubt the front end work is to blame, but you never know -- the cable connector might have gotten jostled during the process. Good luck! Steve K.
- 11 Replies
- 7087 Views
Last post by Vovoroom
- 6034 Views
Last post by misha
- 798 Views
Last post by wizechatmgr
- 2181 Views
Last post by uncletom
- 16 Replies
- 3495 Views
